blank screen
blank screen
Postby William Feltham » Sat Jul 14, 2007 3:20 pm
:( HI PITTI when i put the catch into the print screen and check the pictures to check them and then return to the game the screen goes blank then i have to restart the computer this has happened every time i played the new contest can you tell me whats wrong i am on the new number 70713 thank you william.
William Feltham
Postby Pitti » Sat Jul 14, 2007 5:19 pm
Hi William,
yes, you are right. It's the same for me, if I try to task when the info window is open. It looks like a bug. Before I allways had task after closing this window, so I had no problems. Therefore I can't say, if the previous version had the same problem.
Paul, can you say some words about it?
But this procedure is not longer required. Every catch is automatic written into a file called "score_log.txt". You'll find it in the folder where the game is installed. Open it and look. :)
But please note that you should delete/backup the data content of this file (or the whole file) before the next contest starts. Otherwise you could get a chaos, and you don't know which catch has the current date.
blank screen
Postby William Feltham » Sat Jul 14, 2007 7:17 pm
:D HI PITTI yes i found the log file but how do i send the score to you when i finish the game. thank you .
William Feltham
Postby Pitti » Sat Jul 14, 2007 7:59 pm
William,
post your score in this thread. Look at the example:
http://www.pishtech.com/forum/viewtopic.php?p=1154#1154
Copy and paste one of the examples and change only the values.
You don't need to send it to me.
Users browsing this forum: No registered users and 6 guests
