Packaging content for FFSHD
Postby paul » Tue Jan 03, 2017 9:00 pm
Content creators,
Here's the first step towards making your outings/fish/food/sounds available for Fly Fishing Simulator HD users:
Download the FFSHD Content Packager: http://www.flyfishingsimulator.com/ffsh ... ckager.zip
Copy the application from the zip file to the folder where you want to create packages for FFSHD. Run the application.
IMPORTANT: Use an unencrypted copy of your content for building FFSHD packages. Content encrypted by the RWFF tools won't work in FFSHD.
To package an outing, use the browse button ("..." to the right of the text edit field) and select the outing.def file in the folder you want to package. Click "Build Content Package".
To package a fish species, use the browse button ("..." to the right of the text edit field) and select the fish.def file in the folder you want to package. Click "Build Content Package".
To package a food item, use the browse button ("..." to the right of the text edit field) and select the food.def file in the folder you want to package. Click "Build Content Package".
To package a sound file, use the browse button ("..." to the right of the text edit field) and select the wav or mp3 file you want to package. Click "Build Content Package".
To package a collection of multiple types of content, create a folder with all the content you want to include. Include a subfolders called "outings", "fish", "food", "sound", and include outings, fish species, food items and sounds to be packaged there. The name of your combined folder will be the name of the package.
Content naming guidelines:
Use your name or some other unique a prefix for all your content. For example, if you create a greenback cutthroat trout, and your nickname is "the Dude", name your fish folder the-dude_greenbackcutthroattrout.
I'll reply to this post with instructions for how to distribute your custom content.
Re: Packaging content for FFSHD
Postby Cutch » Wed Jan 04, 2017 4:06 pm
This will not work for my Windows Pro 7, right Paul,...only Windows 8 & 10?
Postby rwwalleye » Wed Jan 04, 2017 8:44 pm
Hi Cutch,
You're right it only works on Windows 8 and 10.
Roger (rwwalleye)
Postby paul » Wed Jan 04, 2017 9:55 pm
The packaging tool is very old school and simple, and that should run even on XP, I think. The actual product, Fly Fishing Simulator HD, will only work on WIndows 8 and 10 however.
Postby paul » Fri Jan 06, 2017 9:20 pm
Content creators,
I've released an update for Android and Windows that supports custom content (iOS still pending... coming soon.) Users of the Premium version for Windows, or who purchase the Unlimited Subscription on the mobile versions can tap "download rivers", tap "download from other servers", and add the URL for any number of content servers.
So you've created outings, fish, sound and/or food files you want to share. You've used the instructions above to create a content package. So how to you set up a content server?
Just create a text file listing the URL for each package, followed by its description in this JSON format:
"outings_to_download":
{"url":"http://www.mywebsite.com/outing_CoonCreek.dat", "desc":"Coon Creek, WI (non-HD)\nWild brown trout feeding at\nsunrise on a driftless region stream"},
{"url":"http://www.mywebsite.com/outing_SquirrelCreek.dat", "desc":"Squirrel Creek, NJ\nA stream I just made up, but\nthere are probably squirrels here"}
If you upload that text file to http://www.mywebsite.com/content_server.txt, then users can simply enter http://www.mywebsite.com/content_server.txt into the app to see and download your content.
You can package and distribute content made for RWFF, at 1024x768 pixel resolution, or higher resolution outings. FFSHD should handle outings of any resolution.
If users install an outing but are missing a fish species, food item or sound, the outing will still run, but the app will display warnings about the missing files for a few seconds. Once people have set up a server or two for fan created content, I'll add a message to the app directing them to the Pishtech forum to find content servers. It will be much easier than ever for casual users to use custom content, so I suspect we'll see far more people using it than we've seen before.
Postby William Feltham » Thu Jan 26, 2017 12:46 pm
Hi Paul cannot make any sense on packaging content for ffshd tried a few times still no luck
help needed. lost all my rwff when my computer crashed and since I am on windows 10 cant install them anymore.
regard's. william
Postby rwwalleye » Fri Jan 27, 2017 6:06 pm
Hi William,
When I switched from Windows 7 to Windows 8 then to Windows 10 when you go to download the game you must do a compatibility check for RWFF then you must make a separate file and list as Games and download the game to that file. A few things you need to know also is the game will not allow you to tie flies plus to play the game go to options and reduce the screen to 800 X 600 and the game should work but it will only take up about 2/3 rds of the screen. I hope this helps in retrieving RWFF plus also you will have to go through and do the updates like before. As for the packaging content for FFSHD Paul would be the one to help you on that.
Roger (rwwalleye)
Postby William Feltham » Sat Jan 28, 2017 12:52 pm
HI rwwalleye I had to back to a clean install only thing left on desktop was the rubbish bin
I installed rwff disc1 and disc3 windows10 says cant install them incompatible and as I had a blank desktop I cant do anything about it.
william.
Postby rwwalleye » Sat Jan 28, 2017 9:45 pm
Hi William,
If when you go to the setup for RWFF if I'm not mistaken do a right click on the mouse and a screen should show up and say check compatibility. Follow the directions from there and hopefully it will get you to download. It may say compatibility to Widows XP or a few other choices. Try each one and it should download then. I had the same problem when I went to Windows 8 and then again to Windows 10. Took me a few tries but i eventually got it.
Roger (rwwalleye)
Postby paul » Fri Mar 03, 2017 6:47 pm
For anyone developing content for FFSHD, here's an updated outing creation tool: http://www.pishtech.com/outing_tool_3_3_2017.zip
This zip file includes everything needed to compile and configure outings. Just unzip it into a new folder, and run OutingTool.exe.
It supports site images of any resolution, and is a little more stable than earlier builds.
Postby geraldro » Mon Feb 19, 2018 4:08 pm
I go crazy with FFSHD, impossible to create an outing. I tried the software proposed above, it does not work :evil:
I create an outing for RWFF and after I convert it for FFSHD without encripter and it does not work, even with your ffshd outings, impossible to mount them in outing tool 2017 .
THANKS
Gerald
Postby paul » Wed Feb 21, 2018 3:20 pm
Please shoot me an email with the details - any specific error messages or crashes, etc. Thanks!
Postby geraldro » Thu Feb 22, 2018 11:09 am
content error
http://fileden.net/8P4
and I'm putting my outing project
http://fileden.net/6dO
many thanks for your help
Postby RUPERT » Sat May 04, 2019 10:37 am
In the event that when you go to the setup for RWFF in the occasion that I'm not worked up all out a correct snap on the mouse and a screen should appear and state check closeness. Look for after the introduction beginning there and ideally it will get you to download.
RUPERT
Users browsing this forum: Majestic-12 [Bot] and 7 guests
