Horseshoe Lake, NY - Night UPLOADED!
Postby wyldechylde77 » Mon Mar 11, 2013 11:14 pm
Hey guys,
Here is the link to download Horseshoe Lake, NY - Night: FIXED VERSION : https://dl.dropbox.com/u/4500652/Horses ... 0Night.zip
*Note this is a complete outing. You will also see a "fish" folder and a "food" folder in the .zip file. For each, open up the folders and place all the fish species folders in your RWFF fish folder, and the food items in the RWFF food folder. I also added the sounds I used to the .zip. Simply place them in your RWFF Sounds folder. I do this to make sure everyone has everything needed for the outing to work properly. As always, if there are any problems, please get in touch with me ASAP to let me know. The sooner I find out, the sooner it's fixed! Enjoy, everyone!!
Description found here in this thread: viewtopic.php?f=1&t=4933
Re: Horseshoe Lake, NY - Night UPLOADED!
Postby FlyManJoe » Tue Mar 12, 2013 12:13 am
Hi Chuck, this outing is another great one. Good job. Just there is one problem. You see the site validation doesn't match for site 4 and I believe until the last site. Not sure if it a problem you can change quickly. But hey at least the first four sites work.
FlyManJoe
Postby wyldechylde77 » Tue Mar 12, 2013 12:22 am
Site validation? Lemme go take a look
Postby wyldechylde77 » Tue Mar 12, 2013 1:32 am
I found it. I just forgot to compile when I made last second changes. I ran it through the tests after all removals and everything worked fine, all sites work. I am also adding all the sounds I used to the .zip file. New link will be up momentarily. Thanks for the heads up, Joe. ;-)
Postby wyldechylde77 » Tue Mar 12, 2013 1:38 am
All set. Just check ed again here, all works as should, all sites work, no validation problems. Please re-download. Sorry about the little oversight. Just turned 36...brain is failing..LOL
Postby FlyManJoe » Tue Mar 12, 2013 4:49 pm
Hi Chuck Excellent quick fix. I really enjoy the big perch in this outing.
FlyManJoe
