how do i insert a image
Postby The Flyfool » Sat May 30, 2009 9:09 pm
how do i do it?
The Flyfool
Re: how do i insert a image
Postby richwest » Sat May 30, 2009 10:03 pm
Hi there Flyfool,
To insert an image in your forumpost, you have to upload your image to a fileserver like fileden.
I use picasa webalbum to get it done.
When uploaded, copy the url of your picture and create your post on the forum.
To insert the picture, click on the Img button (above the editor box) and paste the link like this
    [img]your_image_url[/img]
When pressing the preview button (underneat the editor box) you can check the result.
Good luck.
Postby The Flyfool » Sat May 30, 2009 10:21 pm
thank you
The Flyfool
Postby The Flyfool » Sun May 31, 2009 6:52 am
I testing it here
The Flyfool
Postby The Flyfool » Sun May 31, 2009 6:55 am
what do i doing wrong?
The Flyfool
Postby Yellowstone7 » Sun May 31, 2009 7:41 am
Hi Flyfool:
Welcome to the forum. I have struggled with this problem before too. Here is what I do and this makes things simple. Go to http://www.Photobucket.com and create a free account. Save the picture you want to upload on your desktop, log into your Photobucket account and press "choose file". Locate and choose the file you want and it will be loaded. Copy the IMG code below the picture and paste it into your forum post which you have already started. And voila, it shows up in the post.
I had lot of trouble trying to insert the url between the [img] and I found the above method more convenient as all you need to do is to copy the img url code and paste it. Hope this works for you. :D :D
You can test this and show us a picture of a big smile, or a big fish! :D :D
Postby The Flyfool » Sun May 31, 2009 10:06 am
thank you, it's works!
The Flyfool
Postby Yellowstone7 » Sun May 31, 2009 7:49 pm
Hi Flyfool:
Good to see you up and running now! :) :)
Welcome to the never ending friendly competition at RWFF.
Postby The Flyfool » Sun May 31, 2009 9:50 pm
thank you
The Flyfool
Postby adolfalexander » Sat Aug 05, 2017 7:37 am
I have battled with this issue before as well. Here is my main thing and this makes things straightforward. Spare the photo you need to transfer on your desktop, sign into your Photobucket record and press "pick document". Find and pick the document you need and it will be stacked. Duplicate the IMG code beneath the photo and glue it into your gathering post which you have just begun. Furthermore, voila, it appears in the post. Get dissertation help UK
adolfalexander
Postby adolfalexander » Sat Aug 05, 2017 7:39 am
Sorry I need to dissapoint you, however there is no excursion where you can angle Rockbass yet. On the off chance that you got angle pictures as well as site pictures, the pleasure is all mine to send them. Ready Dissertation Help
adolfalexander
Postby JoannaAquino » Sat Nov 11, 2017 11:37 pm
As it turns out, the process of inserting an image is easy and simple, if to follow certain recommendations. Thanks for helping out!
JoannaAquino
Return to Other
