Opening downloaded files
Postby plantlife7 » Sat Sep 20, 2008 1:52 pm
I am running the third edition (build 70310) on my laptop using Vista Home Premium. Everything runs perfectly but I have a problem updating the programme from your download site.
I can download to my desktop the appropriate zipped file, after trying numerous ways to open them but without success. I have tried double clicking and using the open command only results in the screen flashing, I have no "extract all" on the drop down menu on my desktop.
Please can you advise on this problem.
Thanks. Jean
Re: Opening downloaded files
Postby richwest » Sat Sep 20, 2008 7:18 pm
Running and playing RWFF on Vista has some tricks to do.
You have to install the files to a folder in the root of your harddrive, so do not install it by default.
Create a folder like C:\jean\rwff for example and install the game there.
Then you have to update to version 120 B.80328
Downloading the files, you have to download to the download-folder in your user-profile.
Then copy the zipfile to Real World Fly Fishing folder.
Then unzip the file and copy the extracted files to the appropriate folders.
This should do the trick!
Postby plantlife7 » Sun Sep 21, 2008 12:38 pm
Hi Richard,
Many thanks for your help, I will give this a try and hopefully this will do the trick.
Thanks again.
