116 minimize problem
Postby Pitti » Sat Nov 17, 2007 10:00 am
Hi :)
If I minimize version 116 to the taskbar (ALT+TAB), and reopen it again, the screen will be black. I can fish, but no picture is visible.
That wasn't a problem with version 115.
It's a bad bug, because fullscreen online fishing/chatting isn't possible anymore. :(
Postby geraldro » Sat Nov 17, 2007 12:07 pm
Hi Peter,
I have version 116, and if I minimize and reopen it again, all is ok on my Pc,Maybe it is necessary to update the drivers of the graphics card ?
good day
Postby Pitti » Sat Nov 17, 2007 12:28 pm
Thank you Gerald,
have installed the newest driver from Oct07, but again the black screen. :(
Geforce FX5700 VE, WinXP/SP2.
Postby geraldro » Sat Nov 17, 2007 1:03 pm
Maybe reinstall 116 and restart the pc and make scandisk ?
Postby oppimax » Sat Nov 17, 2007 2:29 pm
Peter,
I got the same problem.
If I came back to RWFF with alt+tab or I clik on the icon in the task bar I got a black screen showing the rod, the blu line, the fish feeding.
I have to move to the up rigth corner looking for the quit botton to go back to the main menu.
In effect wasn't so with 115 release.
Postby dcarp » Sat Nov 17, 2007 5:36 pm
Hello,
I've had that issue for quite some time. I first noticed it when we started using the chat tool - verison 114?? I've just gotten in the habit of turning off full screen mode if I chat and fish at the same time.
Postby Cutch » Sat Nov 17, 2007 11:58 pm
Same problem here. And most of the time when I'm tying flies and minimize RWFF and try to return,...screen turns black and locks up,.... I have to manually reboot. This has been happening for several versions.
Postby paul » Sun Nov 18, 2007 2:49 am
Sounds like something is broken all right... I'll see what I can find.
Postby taupo_tiger » Sun Nov 18, 2007 7:00 pm
hello @ all,
i have the same problem - when i return to the full screen mode game, i have a black screen with the rod and the line left
i fished this dark black site, caught a fish, the pic of the fish showed, and after that the outing picture was loading again, too
taupo_tiger
Postby nccorthu » Wed Nov 21, 2007 2:30 am
I've found that in XP at Least and probably win2K that the WINDOWS Key +M ( WIN Key ,the flag)+M , both together minimizes the screen and comes back OK when you click the icon at the bottom. Only when I have a screen capture going does it trash things but then that is normal all together too often.
Gary Orthuber
nccorthu
Postby nccorthu » Wed Nov 21, 2007 2:39 am
I might note that Alt+Tab does not minimize but switches programs. The effect may be to "minimize" a program but is really not designed that way. the WINKey+M can be undone with either WINKEY+SHIFT+M ( all together or WINKEY+D
Gary Orthuber
nccorthu
Postby thefisher1 » Wed Nov 21, 2007 9:09 pm
Hey Guys,
I have the same problem when iI have the options on Full screen in 1024x768 resolution the game freezes up after you push alt tab when minimized to the task bar.
I don't have any problems though when I turn off full screen and leave the reolution at 1002x768 I can press alt tab and the other page will pop up over RWFF then to get back to RWFF you just move your mouse to an area so you think that the pointer is on the game screen and click your mouse and your back in the game.
Works alos the same with full screen off at 640x480 resolution.
Hope this helps soem of you out a bit.
Theifher1
thefisher1
Postby Pitti » Thu Nov 22, 2007 7:47 am
Hi TheFisher1,
you are right, but for some people like Cutch and me the fullscreen/off doesn't work good, because the mouse is very slow and jerkin.
Hi All
Postby jcroc36 » Thu Nov 22, 2007 6:41 pm
can i ask if you are trying to go back to the game using ALT+TAB, if so have you tried when it is minimised by clicking on the icon on at the bottom of the screen and not using ALT+TAB to bring back to full screen, as this works for me :?: i am using WIN XP.
Postby Pitti » Thu Nov 22, 2007 7:59 pm
can i ask if you are trying to go back to the game using ALT+TAB, if so have you tried when it is minimised by clicking on the icon on at the bottom of the screen and not using ALT+TAB to bring back to full screen, as this works for me i am using WIN XP.
Same result :(
