upgrade 116
upgrade 116
Postby charles » Sat Nov 10, 2007 1:11 pm
Have downloaded latest upgrade 116 and installed into rwf folder.When i press the installer it refers to the previous upgrade 115.
I have deleted rwflyfishing exe and changed rwf 116 dat to rwflyfishing exe .When i run rwf still shows 115 build :?: Any suggestions as it seems rwf upgrade is corrupted
charles
Update 116
Postby oldtrout » Sun Nov 11, 2007 12:47 pm
I also seem to be having problems with update 116. I have, I think, done what the readme says.
Unpacked the files to my rwff root dir and appropriate subdirs. But when I run rwff_update I just get a window with a line of 'gobbledygook' characters and OK/Cancel boxes.
After all this the build shows as 70813.
I am running Vista.
Oldtrout
oldtrout
update fix
Postby Bobcat John » Sun Nov 11, 2007 3:21 pm
Try this it was posted by Piti the creator of the Real World Fly Fishing Club House.
Rename the rwffu.dat to RWFlyFishing.exe in the RWFF folder. This works.
This should fix the probelm othersa have said it does I'm using Vista and it fixed my probelm. Check out the clubhouse and one of our many contest we have a group of fly tiers that are donating their wokr to have prizes for the contest the contest are open to everyone and we would likje you to join in. I'm Bobcat John the prize adminstrator I live in California USA, Oppimax lives Italy and he will be adminstrating the contest, Piti lives in Austria and he cgreated the clubhouse, Dcarp live in Oregan and he wrote or fly tying book and works with Piti on keeping the club up.
I've spent the most important time of my life fishing. What was left over I wasted.
Bobcat John
Bobcat John
Postby oldtrout » Sun Nov 11, 2007 4:16 pm
Thanks 'Bobcat John' for the advice on fixing this issue. It worked for me. Oldtrout
oldtrout
Postby Pitti » Sun Nov 11, 2007 4:43 pm
Oops, I'm too late :lol:
Anyway:
UPGRADE 116
Postby charles » Sun Nov 11, 2007 10:37 pm
Thanks for help did not work for me :cry:
charles
Postby Pitti » Mon Nov 12, 2007 5:41 am
Hi Charles,
are you sure that you copied the version 116? Which build you can see on the game "menu-screen" after copied? The new version shows 71109.
If you give me your adress, I would send the RWFlyFishing.exe to you.
Update 116 - renaming rwffu116.dat
Postby oldtrout » Mon Nov 12, 2007 7:11 am
Charles
As the above advice has worked for me, a thought occurred to me about what might be the problem for you. Sorry if you already know this.
When you renamed rwffu116.dat did you do it in the file explorer?
If so the file might now be called 'RWFlyFishing.exe.dat'. In which case it will not work and the old file will still be there and running. Check this using the file properties in the file explorer.
The file manager usually only lets you change the name and keeps the old extension.
I did the rename via the command prompt to get around this issue.
Hope this helps.
oldtrout
oldtrout
Upgrade 116
Postby GV » Mon Nov 12, 2007 10:24 am
Does this new upgrade 116 include 115, 114 etc or does one have to download each and every upgrade?
Cheers
Graeme
GV
Postby oppimax » Mon Nov 12, 2007 11:03 am
Hi GV,
welcome at RWFF community!
Every upgrade is inclusive of all the fixes of previous upgrades published for this edition of RWFF.
Postby paul » Mon Nov 12, 2007 4:11 pm
The update file has been fixed. You get can it from http://www.pishtech.com/rwffu116.zip
Unzip all the files into you game folder (where rwflyfishing.exe is installed) and run rwff_update.exe.
The only problem was that the zip file was corrupted and wouldn't unpack all the files as it should.
Let me know if you have any further trouble with the update.
upgrade 116
Postby charles » Mon Nov 12, 2007 6:26 pm
Many thanks everybody for all your help and advice upgrade 116 now works : :D
charles
Postby nymphaholic » Wed Nov 28, 2007 5:11 am
after updating to 116 which it says was succesful and the version text verifies that but now my mouse does not work the rod and the little side view fisherman doesn't show. everything else works including the mouse curser.
nymphaholic
Postby nymphaholic » Wed Nov 28, 2007 11:40 pm
nevermind I figured it out. :D
nymphaholic
