new upgrade 114
new upgrade 114
Postby charles » Mon Nov 05, 2007 6:16 pm
have installed this update , but still show build 70813 any suggestions :?:
charles
upgrade 115
Postby charles » Mon Nov 05, 2007 6:20 pm
sorry i correctly installed upgrade 114 , will not show latest upgrade build 115 any suggestions :?: :
charles
Postby taupo_tiger » Mon Nov 05, 2007 7:22 pm
hello and welcome to the rwff board,
try 115
http://www.pishtech.com/rwffu115.zip
taupo_tiger
Postby paul » Mon Nov 05, 2007 7:25 pm
Charles,
If for some reason the rwff_update won't update the program correctly, you can update the files manually. In the case of going from 114 to 115 you can just remove rwflyfishing.exe and rename rwffu115.dat to rwflyfishing.exe. Sometimes the update process is more involved, but since 115 just replaces the executable, that should work fine.
upgrade 115
Postby charles » Mon Nov 05, 2007 8:53 pm
Thanks Paul for your help everything ok :D
charles
