is there a patch for windows 7 64 bit
Postby montana » Sat Oct 30, 2010 12:07 am
I have windows 7 64 bit down load is fine but wont run for me i get no error. this is demo not full game. got it from pishtech.com
montana
Re: is there a patch for windows 7 64 bit
Postby reelfish074 » Sat Oct 30, 2010 1:53 am
which game?
Postby montana » Sat Oct 30, 2010 1:57 am
real world fly fishing demo.I have two gamer pcs and it doesnt work on them
montana
Postby Yellowstone7 » Fri Nov 05, 2010 5:30 pm
Hi Montana:
Sorry I didn't see your post earlier. Yellowstone7 (Stanley) here. A big welcome to our Forum. I too use Windows7 64 bit and I have been running RWFF for six months without any problems. To resolve your installation problem do this:
With Vista and Windows7 you need to install the RWFF program like this:
Do not install RWFF using the default install path. Create a folder called Game (or whatever name you prefer) under your C:\ drive and install your RWFF into the Game folder. The install path will look something like: C:\Games\Pishtech\Real Fly Fishing. The overly protective filing system in Vista and Windows7 require this installation path for RWFF to work.
The default RWFF install path works fine with XP and earlier OS. But starting with Vista you need to do the above. Give this a try and let us know if your game will start for you. Come back if you have other problems. Hope this helps.
Where in Montana are you located? :P
