by syrenstomb » Tue May 16, 2006 9:20 pm
Hey John, take a look and see if you have an Nvidia manager program installed, its included in many of the newer cards driver sets. You should be able to change your frame rate in there. I had to knock mine down to 60hz. If not right click on the desktop, select properties, then the on the settings tab click advanced, then click the monitor tab. You can change your frame rate there. Hope that helps!
