New update available
Postby paul » Tue Aug 14, 2007 5:10 am
I've just uploaded update 114. This changes the artificial intelligence of fighting fish. It should remove the tendency of fish (especially large ones hooked on very light line) to swim to the far shore and thrash against the bank (the "loop bug".) Fish will still tend to move away from the angler in many cases, but will also favor deeper water. A big fish on light line may run, then settle in a deep hole to rest, run again, etc.
Please visit the downloads page (http://www.pishtech.com/downloads.php3) to get the update to version 114 (build 70813.)
Postby Pitti » Tue Aug 14, 2007 5:59 am
After updating to 114 it shows again the build number 70716 and not 70813. Is that a problem?
The Update window comprise not text. Shows only "ok" and "cancel".
Peter
Postby paul » Tue Aug 14, 2007 4:24 pm
Sounds like something didn't work. I've just verified the update file and it worked as it should (bringing the build to 70813.) I'll be in touch by e-mail to see what's going on. Has anyone else had this problem with the new update?
New update
Postby Reg O » Tue Aug 14, 2007 5:45 pm
Hi Paul
I just tried updating to the new version and it didn't work. My screen also only shows ok and cancel.
Reg
Reg O
same here
Postby William Feltham » Tue Aug 14, 2007 7:02 pm
HI PAUL same here says ok and cancel and the update is not on the download page i found it on a google search.
Postby dcarp » Tue Aug 14, 2007 7:11 pm
Ditto here......... :?
Postby paul » Tue Aug 14, 2007 7:58 pm
I found the problem with the update file. It's fixed now. If you don't see it on the downloads page you can refresh your browser and you should see it. You can also get it directly with this link:
http://www.pishtech.com/rwffu114.zip
Sorry for the error. It should be good to go now.
Postby dcarp » Tue Aug 14, 2007 8:11 pm
Works for me!!! Thanks Paul
Problem solved
Postby Reg O » Wed Aug 15, 2007 1:32 am
Thanks Paul for the quick action as always. Upgrade working fine.
I'm also looking forward to the new waters you have photographed.
Reg :D
Reg O
Postby taupo_tiger » Wed Aug 15, 2007 12:27 pm
thanks for the update
taupo_tiger
Postby Cutch » Sat Aug 18, 2007 12:17 am
Yep, works now,...thanks, Paul :!:
getting the update to work
Postby thefisher1 » Sun Aug 19, 2007 12:23 am
Hey Guys,
This may help a few of you guys to get the 114 update to work.
I downloaded the 114 updat then extracted the files to the RWFF folder. Then I clicked on rwff_update in the RWFF folder and it updated everything.
Hope it helps.
thefisher1
thefisher1
Postby kerrye » Sun Aug 19, 2007 3:35 am
Paul, I am unable to install this latest update. I have even run uninstall and did a fresh install of the software. Each time I try to run update.exe I get this error message.
"Error: The Real World Fly Fishing third edition upgrade needs to be installed in the folder whee you have already installed RWFF. The original files are not present where this upgrade was installed.:
Got any ideas? Kerry :(
kerrye
Postby Pitti » Sun Aug 19, 2007 9:09 am
Hi Kerry,
I'm not Paul, but have you extract the zip into your RWFF-Folder and run the update.exe from there?
Peter
Postby paul » Sun Aug 19, 2007 2:58 pm
Kerry,
Pitti is correct (thanks, Pitti!) That error message just means the updater is being run in a location other than where the game is installed. I'm sending more details by e-mail.
