Casting problem with update
Postby JohnM » Thu Oct 29, 2009 9:32 pm
Hey folks
Recently updated to 128 and for some reason I can no longer cast. I use the laptop pad for my mouse. What happens is
the backcast has no line speed so the line basically starts to collapse rather than straighten out behind me. The line falls in a heap on the forward
cast. I reloaded the version 3 software and the casting works fine. All setting seem to be the same. I tried to change some of the setting
of the pad when using the updated version but no change.
Any ideas?
Regards JohnM
JohnM
Re: Casting problem with update
Postby reelfish074 » Fri Oct 30, 2009 1:26 am
i noticed that with the update also........ the casting gets much harder. i just adapted =P but i understand how a laptop would be much harder with this
Postby JohnM » Fri Oct 30, 2009 8:51 pm
reelfish
I fixed the problem by using an external mouse rather than the laptop pad. The external mouse
gave me more of a range of movement. Thanks for the reply.
JohnM
JohnM
Users browsing this forum: Google [Bot] and 6 guests
