color picker
color picker
Postby martin » Sat Jan 19, 2008 6:38 pm
I've downloaded and installed the RWFF color picker from the Clubhouse but can't seem to change colors on either the rod or the line. Any ideas on how I can get this to work? Many thanks.
Martin
martin
Postby oppimax » Sat Jan 19, 2008 6:44 pm
Ciao,
this is the path you must have:
C:\Program Files\PishTech\Real World Fly Fishing\RWFF Color Picker.exe
in the same path you must have linecolor.txt and rodcolor.txt
(C:\Program Files is the default for installation; the one you used if changed)
Massimo
oppimax
Postby martin » Sat Jan 19, 2008 7:01 pm
Thank you very much for your help, Massimo. I'm not nearly as computer literate as I would like to be, but am sure that I'll figure this out in time. The color picker is a great addition to a great program.
Martin
martin
