Logitech Force 3D Pro
Postby Buppers » Wed Dec 26, 2007 3:01 am
Hi Just got the Logitech Force 3D Pro joystick works great But cannot get the Force Feedback to work
Put software in set it up works great in the setup Get in the game the stick
works great but force feed back does not
Think about it see if you can come up with a way to make it work if not I
will take it back
Thankyou Barry (buppers)
Postby the laird » Thu Dec 27, 2007 12:33 am
Hi Barry.
Be sure to go to Options and enable Joystick and force feedback.
I hope this helps Laddie.
The Laird.
the laird
the laird
Postby richwest » Thu Dec 27, 2007 2:47 pm
Just to check?
Do you have the powersupply connected to the joystick,
otherwise the force feed back does not work!!!
I got the same stick, sometimes i have to close the game and
start the game again to trigger the force feedback.
Force Feedback
Postby Ron » Thu Jan 03, 2008 5:58 am
Hi Barry,
I was not getting force feedback as well. I did some research and found this info:
The reason the game is not producing force feedback on is because it tries to access the devices' registry keys with KEY_ALL_ACCESS permissions. Under Windows XP/Vista, this is not allowed for security reasons
- Right-click on the program’s shortcut
- Select "Properties".
- Go to the "Compatibility" tab
- Under "Compatibility mode" mark the check box labeled "Run this program in compatibility mode for:", and select "Windows® 2000" from the drop down list.
Hope this helps,
