Mending the line?
Mending the line?
Postby Pitti » Tue Dec 25, 2007 9:44 am
Hello :)
Merry Christmas at all!
Have you ever tried to mend the line? Is it working for you?
I found that if I made a long cast and uplift the rodtip, the line is shorten out of scale to the rod-up-movement. So I can't find a way to mend the line.
How do you mend the line? Are you able to do it and how?
Postby richwest » Tue Dec 25, 2007 11:38 am
Merry Christmas Peter,
On a long cast, putting up the rod doesn't work for me either.
To take the fly back just a little, Ireel in ust one or two clicks
and then give back some line.
It works for me, most of the time!
Postby Pitti » Wed Dec 26, 2007 9:12 am
Hi Richard,
Thank you :)
I did mean more if anybody is able to cast/lay a curve upstream without taking the full line out of the water, if the fly begins to drag.
Postby richwest » Wed Dec 26, 2007 10:34 am
Peter,
I get your problem, i haven't tried this before,
i will do some investigations on that in the comming days
and see if i can get it done 8) 8) 8)
Richard
Postby Cutch » Wed Dec 26, 2007 4:39 pm
Peter,
I have tried casting as you're suggested so the curve of the line is upstream from the fly, but so far have been unsuccessful. (so mending the line is not needed) :oops:
Postby Pitti » Wed Dec 26, 2007 9:50 pm
Hi Cutch,
Yes for catching the RWFF-fish mending the line is not needed, but it would be funny if we could do it. :)
I would also like it to cast more special-casts beside normal and rollcast.
Like speycast and snakecast or so..
Speycast:
Snakecast:
Mending:
