Patch Locations and How to Install them
Postby wyldechylde77 » Fri Mar 08, 2013 3:20 pm
Hey all,
Just thought I'd help limit the confusion for new members by posting the locations of each patch and the steps to install them. This will make things easier for new anglers to keep things up-to date. I copied and pasted info from a PM I had sent to Cutch to help him get to v133.
When you get the game, I believe you will be at v128. First, download and install the v131 patch, here is the v131 update:
http://www.pishtech.com/rwffu131.zip
Install that, then check the game and make sure it says v131 in the bottom corner.
Now, apparently something went weird after that update, so you have to install this as well:
http://www.pishtech.com/strength_fix.zip
Again, make sure it installed and I THINK your version # will be 132. I THINK.
Finally, here is v133:
http://www.pishtech.com/rwffu133.zip
Make sure after install your version is 133. Should be good to go then.
Any more problems, I'll try to help you as best I can
Re: Patch Locations and How to Install them
Postby Scottish Warrior » Fri Mar 08, 2013 6:45 pm
Hi Chuck,
Great Help,I have made the post a "Sticky" so that it will not move down the List.
Cheers Martin.
Postby manoj2078 » Tue Mar 12, 2013 5:15 pm
thanx alot mate one of the best topic for everyone coz i didn't know about 133,till i read this.
thanx manoj
manoj2078
Postby Doc » Thu Apr 25, 2013 12:14 pm
To maybe help new guys I downloaded RWFF yesterday it is v1.31 - BUT the rwffver.txt syas it is 1.28 AND the game screen says 1.31 in the bottom RH corner.
Which of the files mentioned should I now use to get as up to date as possible - I see 1.38 is in Beta - does that mean that 1.37 is available?
Many thanks for a great game. One very small gripe - even with the new sound downloads from the Clubhouse the water sounds are very quiet - if I really turn the volume up then the audio help blasts me out lol. Apart from that this is one awesome game - thanks for the time and effort - I don't fish but love this sort of game - I think wwiionline will be taking a backseat from now on!
Cheers
Doc
Doc
Postby Barns » Thu Apr 25, 2013 12:43 pm
Doc
Try updating to version 133. This gives a lot of fixes to game. V137 only getting tested at moment . So v133 is latest.
Barns ( Brian ) Scotland
Postby Doc » Thu Apr 25, 2013 1:00 pm
Thanks Brian - just the 1.33 update file works a treat on top of the latest purchasable version.
Cheers
Doc (Dave - Wirral, England)
Doc
Postby Yellowstone7 » Wed Aug 27, 2014 9:09 pm
You can now update your current RWFF install to V.142 by downloading and installing this latest zip file from Paul. Download it and unzip the contents right into your main RWFF folder and you should be good to go. :lol:
http://www.pishtech.com/rwffu142.zip
This V.142 update incorporated all the "in-between updates" since V.133 in one package. It works great!
Postby badger040 » Sun Apr 05, 2015 11:50 pm
can someone post a strength update please
the only update in the sticky for patches posted by Chuck that is still downloadable is V.142
thanks in advance
Postby Yellowstone7 » Mon Apr 06, 2015 9:51 am
Hi All:
You can download "strength fix" patch for V.132 and later versions via this link. This will fix the problem of a medium sized fish taking a very long time to land.
https://dl.dropboxusercontent.com/u/734 ... th_fix.zip
Postby wcandres » Thu Jul 14, 2016 3:25 am
Is the "Strength" patch needed if you're running version 1.42?
wcandres
Postby Yellowstone7 » Thu Jul 14, 2016 8:32 am
HI wcandres:
The new version should have included the strength patch so it is not needed. :P
Postby wcandres » Thu Jul 14, 2016 1:24 pm
Got it! Thanks much, for responding.
Bill
wcandres
Postby Jack102 » Sun Apr 15, 2018 2:22 pm
Thank you for your help
Jack102
Postby smithassignment1 » Thu Apr 19, 2018 5:16 am
Please tell me a easiest process to update. V.142 is still not downloaded. I am not able to locate the sticky patches and the steps to install it.
smithassignment1
Postby Kigiin » Wed Jun 27, 2018 3:51 pm
This has been quite helpful - thank you.
Kigiin
