NEW OUTING PROBLEM
NEW OUTING PROBLEM
Postby thefisher1 » Sat Nov 24, 2007 12:01 am
I've been playing around with the new outing tools and have tried to put a outing together.
The outing image shows up and when clcik on the outing in the ock tool an error pops up that says, gr has encountered a problem and needs to close.
Anyone have any ideas on whats happening.
Thanks,
thefisher1 (Dan)
thefisher1
Postby dcarp » Sat Nov 24, 2007 2:09 am
Dan,
I had the same issue earlier today so i copied my .def files from a previous outing i created then edited them as required, then it started working. I'm not sure though which one was causing me problems because I moved all three files at the same time.
I'm guessing it worked because I had those .def files from the first release of the OCK.
Postby Cutch » Sat Nov 24, 2007 9:30 am
I was getting the Ig error message too. Dave's suggestion worked for me. Thanks Dave. :wink:
Seems this problem started with the encrypt feature? :?
