help please can't update 116
Postby thefisher1 » Sun Nov 11, 2007 9:22 pm
Hello,
I can't seem to get the 116 update to update.
I installed it like everyoner says and when I click to update the gray window doesn't say update tp 116 its blank only has cancel and ok.
Any suggestions on how i can get this to work right. 114 worked fine 115 have a few problems with and now 116 I can't run.
help please,
thanks
thefisher1
thefisher1
Postby paul » Sun Nov 11, 2007 10:22 pm
I'm working on a fix for the update. The quick shortcut is to rename rwffu116.dat to rwflyfishing.exe. That works in this case since the application itself is the only thing that's changes since version 114. I'll post a message here when I've got the updater issue solved.
Sorry for the trouble.
Postby paul » Mon Nov 12, 2007 4:11 pm
The update file has been fixed. You get can it from http://www.pishtech.com/rwffu116.zip
Unzip all the files into you game folder (where rwflyfishing.exe is installed) and run rwff_update.exe.
The only problem was that the zip file was corrupted and wouldn't unpack all the files as it should.
Let me know if you have any further trouble with the update.
I cannot either
Postby the laird » Tue Nov 13, 2007 5:24 pm
I am not very computer literate.
And do not ken how to change this or that to this or that.
so there will be downloads I will not be able to use.
But it does not bother me because it is such a great game.
the downloads that find their own way home will have to suffice.
It is still worth it.
Thank You Kindly.
Tha Laird.
the laird
the laird
116 FIXED
Postby thefisher1 » Tue Nov 13, 2007 8:07 pm
Hey Paul,
Thanks for the fix evrythings working great now.
Thanks Again,
Thefisher1 (Dan)
thefisher1
