New Update V113
New Update V113
Postby Pitti » Mon Jul 16, 2007 1:57 pm
Hello :)
Paul has build a new update. There were problems with some codes, which gave wrong fish-datas back, so that I was unable to validate it in some cases. Also some small bugs about fish behavior and other small problems are corrected.
You know the install-procedure. Unpack the zip file into your real flyfishing folder (click "yes" if it ask to overwrite some files) and start the rwff_update.exe from that folder.
Then check the new version at the menu screen. It must be now
build 70716.
Btw:
You can keep your existing scores for the current contest (I hope we have no problem if we calculate it), but if you want update them, please use only the 113er version as from now.
Download V113
Postby oppimax » Mon Jul 16, 2007 2:19 pm
Thanks Pitti,
if I upgrade the game, for this contest, probably I'll post codes generated with build 70713 and codes generated with build 70716.
It's correct? This is a problem for you? I wouldn't like to loose the scores I got till now! :(
Let me know. :)
Ciao e grazie!
Postby Pitti » Mon Jul 16, 2007 2:23 pm
Hi oppimax,
No, there are no problems if you do this. You will not lose any score. :)
Regards from a very hot Berlin 8)
Postby oppimax » Mon Jul 16, 2007 2:46 pm
OK.
Also in Genova is very hot!
Too hot to fish outside? Let's play RWFF inside!
massimo
:D
Users browsing this forum: Google [Bot] and 14 guests
